Hello,
I’m hoping someone can help me out… I have gone through all the information in the pool school tabs and have done more research on the side. My pool is a fiberglass pool, approx. 23,000 gallons. I just moved into this home and trying to maintain the pool levels has been a bit of a struggled. I’m on a well and my water has a little bit of calcium in it to start however, I don’t believe that is my issue. I tested my water levels and now have a base to go off of…
CH: 750
TA: 200
CYA: 90
PH: 7.5
FC: 1
Chlorine: .5
CC: 1
I realize my levels are not good and I know I need to address it before it gets worse. My question is what do I start with? My thoughts would be to add acid to lower my TA levels but I’m not sure how to determine how much and if that’s what I should start with. Any advise would help a lot. Thank you for your help! Also, I live in Las Vegas and my pool is outdoors. It’s already about 90 degrees here…
CH: 750
TA: 200
CYA: 90
PH: 7.5
FC: 1
Chlorine: .5
CC: 1
