Good morning,
This is my first post asking questions. So I've done some reading on this forum regarding balancing chemicals, I've purchased a TF100 kit and a speedstir and now I'm about go it alone, that is cut the cord from the local pool supply store.
I have many questions about pool care, the equipment, etc. My main task right now is to get the chemistry balanced. I'd like to use up what supplies I have left from the $$$ pool supply store. But if that's not a option then I'll sell them or get them disposed of properly.
I'd did my first test yesterday. Everything seemed to go ok. A few little gotchas as far as handling the bottles. One of the bottles sprayed me when being opened for the first time. Didn't expect that but I'm still alive. Ironically it was one of the bottles with the most warnings on the label.
I did the daily test first...
Cl is greater than 5.
Ph = 8.0 or higher.
FC = 7
CC = 0.5
TC = 7.5
CYA = 100
TA = 140
CH = 975
I've been using Power Powder Plus (73% Calcium Hypochlorite) and 3" Jumbo Tabs (Trichloro-s-triazinetrione).
I took what was left of the 3" tabs out of the pool and added 48oz of Acid (according to the PoolMath App).
What should do next? I'm planning to do all the tests again today. I need the practice...
With Calcium Hardness being so high I really need to drain. My question is can I wait until the Fall or Winter?
Can I continue to use Power Powder Plus until it is used up then switch to bleach?
Thanks!
Strop
Ph = 8.0 or higher.
FC = 7
CC = 0.5
TC = 7.5
CYA = 100
TA = 140
CH = 975
Thanks!
Strop
