I'm trying to drain my pool for some construction work.
I noticed it stopped draining after passing below my skimmer basket, it starts to drawing in air at the pump. I did some research on the web and realized I had to plug both drain holes in the skimmer. After pluggin up the holes, my pump tries to drain but only prime and then turns off because there is no water flow. Could it be my 2 main drain lines in the bottom of the pool is clogged?
Any suggestions that you think I should try? Thank you.
I have a in-ground, concrete pool.
