SUre!
I had a hard time deciding because I like both dark pools and ones that have a brighter color. I ultimately chose Tahoe because the color varies a lot depending on the lighting conditions and your vantage point.
The closeup photo that appears to be bright aqua are taken standing right next to the pool at the deep end on a sunny day. The medium blue ones were taken at the same time, standing at different angles in relation to the pool (eg 200 ft away, from the hillside above versus next to the pool). The ones that look greenish grey were taken on a winter morning without much sun. Most of the time, the water looks bright and blue or dark aqua as it does in the brighter photos. Really, the photos do not do the finish justice.
Note that we added glass beads to the mix ("Luminous" in jade mix, an equal blend of blue, green, and clear glass). I don't think this mix alters the color but it makes the water look brighter. It is also available in blue mix or emerald (green only) if you prefer a different shade.
One consideration is whether you plan to use colored lights, because they are brighter with pools that are light of medium color, I think Tahoe is about as dark as you can go and still have the colored lights show up very well.
