- Sep 22, 2022
- 6
- Fiberglass
- Pentair iChlor 30
My recent pool install is a 16k gallon fiberglass with pentair equipment (inelliconnect and swg) and raypak heater.
The installer did not connect the heater to allow operation through the app. My understanding is that you can connect a temp sensor inline, set the heater at the top end, and then have a fireman's switch so the heater gets turned on or off based on the temp you enter in app via the temp sensor.
I asked about why they didn't install that connection and received this response - "That is purposeful, for two reasons. The app cannot control the temperature, and the heater has an internal thermostat that functions better than installing a separate temperature sensor that gets drilled into the pipe.
We historically got much better feedback about the temperature sensors that the heater has already installed in them so we just use those as they provide a better, and more consistent result."
True? BS? Somewhere inbetween?
Thanks for your perspective and experience.
