Truclear problems and questions
dougm216
Active member
May 13, 2014
27
Port Charlotte, Fl
Just got new 1766 test kit. Same readings as all others I have used. 3800 salinity. FC chlorine down to 3. I'll do set of tests in the morning. OCLT tonight. Doug
dougm216
Active member
May 13, 2014
27
Port Charlotte, Fl
Here we go again. All tests on the mark. Salt is at 3800. Oclt dropped .5 Pump on all night and swg off. I'm going to run pump 24 hrs swg on boost. I bet it slowly goes on down. As others have stated and pool company, at these settings there should be enough Fc being made to bleach everything. Yet nothing.
ping
3,125
Long Beach, CA
Do you know what chemicals have been added to the pool?
Have you checked your program out that it doesn't reduce the chlorine output during the run? It seems that it was only making maybe 1/2 the chlorine that it should at one point?
Have you turned off the SWG for several days and dosed only with liquid so you have an exact amount of chlorine it is using at the moment?
dougm216
Active member
May 13, 2014
27
Port Charlotte, Fl
Yes
Not sure how program at 100% 24 hrs a day would reduce chlorine
Pool builder is supposed to be back, we will see.
Also Jandy supposed to involved now.
carnivalday
555
Ocala, FL
Hey there. It depends. For the past few days, I had it at 1800 because I didnt have my solar on. Today I bumped it back up to 2200, because I turned the solar on. My SWG is at 40%, and I checked FC this morning; its 9.5. Its high, but thats okay. Id rather be too high than too low. And we finally have sunshine.
carnivalday
555
Ocala, FL
Im sure you already have this, but in case you dont:
YippeeSkippy
13,421
Evans, Georgia
ok, I don't have the same SWG but I don't seee "fizz" in my cell, I see "smoke" which is the chlorine gas production. Could you be looking too hard for bubbles and missing another sign of the cell working?
Is anyone using your pool and possibly using up your chlorine? A kid peeing, perhaps? A party of kids daily??
Have you yet tried to capture water immediately out of the return and test it? It should test higher in FC than the rest of the pool, which nyou also need to test at that time.
maddie
dougm216
Active member
May 13, 2014
27
Port Charlotte, Fl
Hey folks
Finally got pool builder to replace salt cell, after a year. Low and behold have bubbles out of all returns, only a few bubbles out of 1 return before. FC has been going up everyday instead of down and pool is crystal clear. Thank you all for your ideas and suggestions.
