I have what I believe to be a leak in the skimmer return.
I have an in ground 20K gallon vinyl pool. I got about 13 years out of my liner and I'm having it replaced when it warms up in a month or so in Atlanta.
Currently, my water level drops about an inch every two days. It stops dropping once it gets below the skimmer level.
I have closed the three way valve to segment the suction from the skimmer. I then filled the skimmers and the water level drops about an inch an hour until it disappears into the pipe below both skimmers. I have used dye to observe the leak, but it must be pretty slow because the dye dissipates before I can be certain.
I would assume that a leak detection is in order, but wanted to get ideas about further troubleshooting before my liner is replaced or the leak detection takes place.
I have read that suction leaks are rare underground...but I have a rare ability to find rare problems.
Thanks for help!
Thanks for help!
