Hi,
First time pool owner here, and doing my first slam. I have a new fiberglass pool with a saltwater system. I had everything up and running good, chemicals all within a reasonable range. My CYA was ar about 45 and chlorine was mostly in 4-6 range.
The problem:
I had my saltwater machine set on 50 and my chlorine was up around eight. I turned it down too quickly and my chlorine dropped to zero. I turned it back up, but could not generate chlorine and the water started to get cloudy. I realized I probably had an algae bloom and I needed to SLAM the pool pool.
I am on day three of the slam. I have used 20 gallons of liquid chlorine. The pool has been crystal clear for three days, but it will continues to fail the overnight chlorine test. Should I continue with the SLAM?
Also, when the water got cloudy, my CYA had dropped to zero.
Should I continue the slam without any CYA or do I need to get some CYA in there to help the pool retain its chlorine level?
Thanks in advance for any advice!
Jon
The problem:
Jon
