- Jul 10, 2012
- 54
- Plaster
- Jandy Aquapure 1400
My wife and I bought a new house last August with a 19,000 in ground pool. Our last home had a 7,000 AGP so I know enough keep the new pool from turning green. A few months ago, I heard a strange noise coming from the pump after a strong storm. It turned out the pump was cavitating and very little water appeared to be moving through the pump's skimmer basket. The pool skimmer was completely full of leaves. I tried to pull the basket out but there was so much suction, I had to turn the pump off first! After I cleaned the basket and turned the pump back on, I began to wonder if the main drain was drawing any water from the pool. Fast forward to a few weeks ago. With warmer weather upon us, I took time to dive into the pool and remove the cover from the main drain. There appear to be a bunch of silt under the cover. I stirred up the silt until the pool began to get cloudy and turned on the pump. The silt didn't react except to fall to the bottom of the pool. I shoved a garden hose into the the pipe off the drain and was able to feed about 12 feet into it. I'm sure it stopped due to a 90 somewhere in the system. I was unable to clear the blockage with the hose on full and there was no improvement when I attached one of those expanding bladders to the hose and tried again. I tried putting the hose into the suction side of the pump and the pool skimmer, but each time, the water came out the other side with no movement at the main drain.
I'm at my wits end over here. There are two ways for water to get out of my pool, the skimmer and the main drain. There is a single pipe that emerges from the ground and goes into the suction side of the main pump. My skimmer has a single hole at the bottom so I know the main drain isn't running through the skimmer. My only guess is that someone connected the skimmer and drain together somewhere between the pool and pump, but I'd rather not dig it up and begin hacking apart the lines looking for the blockage.
How can I find/resolve my blockage issue?
