- Jun 1, 2018
- 16,019
- Vinyl
- Hayward Aqua Rite (T-15)
If cya reads anywhere between 70 & 80 you call it 80 & that’s a slam level of 31 ppm.
You can also do the diluted cya test to confirm your suspicion - Step 8
www.troublefreepool.com
since your pool is clear it may not take long if u find the source/hiding place so long as u are indeed at slam level.
CYA - Cyanuric Acid Test
Cyanuric acid (CYA) is the chemical name for the product commonly called “pool water stabilizer” … Read more…
