I am adding muriatic acid (31.45%) multiple times a week (typically 20 oz increments) and a little concerns something is not in balance. I am considering raising my TA to 80-90 ppm but wanted to floor this to the group before I do since poolmath calculator likes it at 70 ppm.
Below is a representation of my recent chemistry (I use Taylor chemicals):
FC - 3.5 ppm (FAS/DPD) (ranges between 3 and 4.5 depending)
pH - 7.7 or 7.8 (color test)
TA - 70 ppm
Calcium Hard: 230 ppm
CYA - 60 ppm (see note 2)
* Other notes
1. Hayward SWG (set at 45%; 8 hr pump run time daily)
2. I am considering raising CYA to 70-75 ppm after I check my testing agents via TFTESTKITS sampler that I ordered today that includes CYA solution calibrated at 50 ppm
3. Sometimes add Dichlor (Clorox Shock Plus) to augment SWG.
4. Phosphates are approx 1100 on average when measured by Leslies AccuBlue tester). My own testing (using phosphate strips) are inaccurate but seem to be close to 1000 based on shade of blue.
plan to lower phosphates once I have sustained balance.
Thank you
Bob
TA - 70 ppm
* Other notes
Thank you
Bob
