Hello everyone, having a bit of a problem. I had another thread about cya not registering, with no reply but it seems my issue is a little bigger.
Long story short I started with a fresh fill, and couldn’t get CYA to register. Maybe the water was too cold, plus I didn’t know about the sock method, I tried mixing with a bucket and pouring the cloudy water (mixed, not the granuals) in the skimmer.
Sadly my first mistake, or second rather, was I let the FC drop to 0 a few days after filling. with no CYA In the pool, the LC got gobbled up. When I noticed the pool was cloudy, the pool store was closed so I ran to the supermarket and somehow bought and put 2 jugs of cloramax in, which I read on here is a polymer and a no-no. I then used the sock method.
Since then, my chlorine is being gobbled up extremely fast. I’m sitting at 17.0 FC and .5 CC per the DPD test at 8:30 pm. However at 5:30 I was at 21ppm.
Last nights OCLT showed 1.5 loss.
I’ve read a few threads talking about ammonia on here and I’m afraid this may have happened.
I swear I had a reading a few days ago of 20 or so CYA and I thought finally, it’s dissolving, but now I’m back to 0. Have not backwashed
My drop test for FC was red? And PH off the chart, when it was just 7.2 a couple days ago
Surely I’m past slam levels with no cya in the pool? Am I fighting ammonia at this point? Any help is appreciated.
Also, I broke a cardinal rule and brought some water to the pool store just to see if my regeants were bad, all they recommend was some “fresh n clear” and some acid to reduce the ph. I declined on both.
