- Jun 1, 2018
- 14,059
- Vinyl
- Hayward Aqua Rite (T-15)
No, Your swg will make chlorine which will then be converted to bromine because of the sodium bromide bank present in the water.I guess the confusing part is that if I have say 1500ppm of Sodium Chloride, having only 30ppm of sodium bromide in the tub means that my SWG will now make bromine?
Your swg only directly creates bromine at the higher sodium bromide levels listed in the manual.
At least that is what I gather from the manual & the operation of other generators that are capable of doing both things.
Yes- Once sodium bromide is in the water any chlorine added then turns into bromine -The tub will be bromine instead of chlorine even though NaCl is 1500ppm and NaBr is only 30ppm?
You can turn a chlorine tub/pool into a bromine tub/pool but you cannot convert the other way around without replacing all the water to remove the sodium bromide as it generally never goes away.
There’s even a saying, “Once a bromine pool always a bromine pool”.
