I'm currently living in my first home with a pool. No previous experience growing up or anything so pretty inexperienced.
I recently went away for 5 weeks and left my pool unmaintained.(stupid I know)
When I came back, there was so much build-up of leaves etc. that the pump had effectively stopped working because there was too much pressure. I cleaned it all up and hosed down and cleaned the DE filter like the tutorial.
Pool looks OK now apart from... The pressure in the pump is too high, over 30 and so not really working. When you first turn it on, it will run for a couple of hours before the pressure builds up so much that it's useless and I turn it off. I tried backwashing again without adding any more DE and it didn't do anything, the sight glass looks clear.
Anything else I can try myself? Or anything I should be forewarned about if I get in a professional to take a look?
Thanks!
Thanks!
