To close or drain?
Notauser
Active member
Jun 3, 2020
33
Gainesville, GA
First year pool owner here. I have an 18’x36’ in ground, plaster surface that has been painted, chlorine pool, 2 skimmers, 1 main drain, 8 in floor cleaners that double as my returns, with attached spa. I’ve gone through many articles on here about closing but it seems to be a given that you close your pool instead of just draining it and starting new next year. Why is that?
Other than opening the hydrostatic pressure relief drain, paying for water (which is cheap here) and replacing the calcium and CYA, is there another reason why people close pools instead of drain and refill? Does the plaster age prematurely without water, and/or does it matter mine is painted? Or does the empty pool collect stuff on the sides and bottom that make balancing the water harder when you fill and open next year? Any help is appreciated. Thanks.
You are in a hard place...
1. your pool is painted and that will only last a certain amount of time before needing repainted when it is under water, so with no water it will last longer...
2. your pool also has plaster and plaster should always stay wet because it dries out and can crack...
Those 2 statements are the problem as they conflict each other...
Well the pool sat empty for at least a few years before filling up with rain water and 65 gallons on mud...ask me I how I know that number! So the plaster is already rough and ready for a refresh but doesn’t leak. But after buying the house with a swamp in the pool, we just painted it to get it going this year.
But I did not know about the plaster drying outside of water. Is that why most people have tile at the water line?
that is exactly why tile is used on the waterline... That allows the water to go up and down 6 inches and the plaster is always below water...
