To clean DE filter or not to clean
hexabc
Here is my question. I opened the pool in the middle of May. Very clean, transparent water. After a couple of hours I could swim, but since the water was icy cold, I didn't. Two months have passed now, the pressure on the filter stays at 10psi level, the same as right after startup. Now, is there any reason to clean the filter and replace the DE? In the hope of even cleaner water? :)
If the pressure stays down and the water is clear it's fine. If it ain't broke, don't fix it. I tear mine down once a year when backwashing won't lower the pressure. If you keep the levels right the filter isn't working very hard.
