- Jul 4, 2020
- 515
- Vinyl
- Pentair Intellichlor IC-40
I’m in the final stages of setting up my equipment pad. I just started planning for bonding connections to my equipment, and it hit me that the Siemens transfer switch / disconnect does not have a bonding lug. Under normal circumstances, it would not need one, so I wouldn't expect it to have one. It is obviously connected to ground, and I understand that through connections in the motor, etc. the ground and bond are implicitly connected, but wondered how Article 680 treats this sort of thing. Should I order a bond lug, remove a bit of paint, and install it? Picture below in case it helps you visualize things.
