I am trying to find a setup to ensure my chlorinator pump only turns on when my pool pump is running. If the power goes out, I can see a scenario where the timers are out of sync.
Currently, I use a Woods digital timer for the chlorinator pump and a GM40AV mechanical timer for the pool pump. I would like my GM40AV pool pump timer to control both the pool pump and the control whether the chlorinator pump can be activated when the digital timer's program activates.
Here is my setup.
I have a GM40AV timer in my pool panel. Currently it switches both legs of my 220v pool pump as shown below.
I may be mistaken, but I understand that you can wire it to switch one leg instead of both (without additional current draw). In theory this would free a switch for a 120v circuit (powering my stenner chlorinator pump). I've attached my proposed wiring diagram below.
My main questions: Can you see any reason not to do this? Has anyone else done this before?
Thank you,
Patrick
Here is my setup.
Thank you,
Patrick
