- Nov 7, 2018
- 1,049
- Plaster
- CircuPool RJ-60 Plus
I have been on TFP for several years and have had no issues with water clarity while using the TFP system until now. Long story short, there is slight milky haze to my normally pristine and crystal clear water. On occasion, a rain storm will wash some organic mess into the pool, but will clear up after a couple of days running the pump and running the robot a few times. However, after the last rain (6 days ago), I have not been able to clear the pool to what it looks like normally. The pool water has just now reached 60 degrees with the warmer temps and I have pushed up the chlorine levels the last few days to see if that would help clear it (with LC, not using SWCG yet). I have also installed brand new filters just to alleviate that as an issue. Previously, any cloudiness I saw was usually because the PH had crept up but a little MA would clear it back up in short order. Anyway, here are my current numbers:
FC: 12.0
CC: 0
PH: 7.6
TA: 100
CH: 550
CYA: 70
SALT: 2400
CSI: -0.02
Temp: 60
I do not winterize the pool and run the "full test" about once a month in the down season. My PH tends to creep up gradually, so I add about 2 cups of MA once every couple of weeks. The only numbers that look askew (from normal) the CH (normally around 325-350) and TA that has been consistently 70-80. I did an OCLT yesterday and had a zero FC loss. So, does anything stick out to all you smart TFP folks? I thought I would check in before starting a SLAM.
FC: 12.0
CC: 0
PH: 7.6
TA: 100
CH: 550
CYA: 70
SALT: 2400
CSI: -0.02
Temp: 60
