I have an old pool with an old DE filter (with “fingers”) and a new 1.5 hp Hayward single speed pump. I have only one skimmer working, not sure why the other skimmer doesn’t work. Two return jets work. One underwater light does not work. As you can see from my signature the pool is pretty big 40,400 gallons. Would you recommend a switch to SWCG? Is a good estimate between $600-$900 as I noted on another thread for someone else’s pool?
The pool will also need a replaster before too long. Does a SWCG have any effect on the condition of the plaster? So three items that need work, and one somewhat major change to SWCG. What is the general thought/recommendation on the sequence to have this work done? Replaster, light, skimmer, SWCG?
