It's been about a year since I went through this, a few months after I installed the solar. I'm pretty sure it happened at high speed also, I should put the VRV back in and check my memory, maybe I'll do that this weekend.
Even at low speed, although I can intuitively accept it more easily, I have trouble explaining exactly why any part of the pressure side would be below atmospheric in a completely closed system with the jets having noticeable pressure.
Oh I'm not challenging the physics - after all if it ain't physics it's philosophy... It's just a matter of phiguring out what's going on, how the system might be compromised, I have reused pipe with fittings. Maybe there's a small leak on the suction side that'd explain it...
Regardless, I plan to run the peristaltic pump only while the pool pump is on low speed, so it sounds like this bodes well for injecting the CL into the down pipe.
