This spring I will finally conquer this stain
borjis
3,385
Pacific NW
Wow that is some stubborn stain.
I'm not sure what to recommend.
Maybe call Jack's magic & tell them what happened. See if they have any further advice.
I'd do that before spending more money.
Reactions: heyyou488
JamesW
24,107
#2 is sulfamic acid. I don't know what #1 is.
I suspect that a zero alkalinity treatment or sulfamic acid would be the best bet.
You might be able to combine both methods for better effect, but I really don't know.
Since I don't know what chemical #1 is, I can't comment on it unless you can find out what it is.
heyyou488
22
Pflugerville, TX
I have called and emailed Jack's Magic and they told me the "area support rep" would be in touch with me likely in the next 24 hours. Hopefully, he will have some thoughts on the best way to proceed.
I would suspect combining with zero alkalinity may be the best idea as the directions do say that when testing on a step, it may be beneficial to pour some additional acid on the spot prior to test.
Either way, I am planning to talk to the rep and see what is possible. The weather here is not hot yet so I have a little more play time to figure this out before the kids will demand the pool to be swimable. HAHA
Reactions: borjis and JamesW
heyyou488
22
Pflugerville, TX
Spoke with the Jack's Magic rep and he has advised me to keep the PH at 7.2 and apply 1.5 qts (for a 15K pool) to the water and brush frequently. He is currently planning on coming out to check out the progress next week and see what can be done from here. The current thinking is this will help loosen the stain and then another test may return a more obvious result.
I will say after 24 hours the stain appears a bit lighter and where I had applied stain test #2 appears is a white streak in the stain. So perhaps this is helping? In the meantime, I am planning to brush 2 to 3 times a day until he comes out and adding acid to keep in line as needed.
