Hello,
I currently have a thin layer of some type of white/colorless film around the walls and bottom of my pool. When I go to wipe it, you can clearly see where I was able to remove some of it. It feels a bit slimy or slippery at first but then goes away quickly when wiped with my hand. Brushing and even with using gloves doesn't seem to remove it, comes off easiest with my hands.
Im currently in day 3 of the SLAM process. Passed the OCLT with a .5 last night, and water is clearer than its ever been, but the film is still there on the walls and bottom of the pool.
Test results were as follows:
FC: 10
CH: 350
ALK: 70
CYA: 20, added 10PPM worth of granular through skimmer 3 before I started slam 3 days ago.
Any ideas what this might be or what I can do to fix this?
Thanks!
FC: 10
CH: 350
ALK: 70
Thanks!
