That would help.I can make a video of the MasterTemp display while short cycling if you think that helps.
Have you checked the error lights on the back of the board when the heater shuts down? You'll have to remove the board and watch from the back to see what happens as the heater starts its ignition/heating cycle.here's heater startup video... kinda tough to shoot alone but if you missed it, the heater comes on, the red lights both flash, it displays 128 as a temp, then R14, then the water temp... and the heater light beging to flash amber indicating the demand for heat is there.
in the second video, I captured the firebox coming on a few moments later.
Hi, have not checked lights in back of board yet, nor running with regulator out. I plan to do that today and tomorrow. Got a lot of stuff on the go. And no I did not base my troubleshooting of the thermistor on the startup numbers, it was based on the temp showing 126 (not 128) and not coming on at all. New thermistor allows it to come on but short cycle like last year. When I pull the regulator i will take a photo of the internalHave you checked the error lights on the back of the board when the heater shuts down? You'll have to remove the board and watch from the back to see what happens as the heater starts its ignition/heating cycle.
Not sure if it is the video itself, but the blower does not sound good.
Normal startup display on the heater is:
Display on and 888
Service Heater lights and goes off
Service System lights and goes off
128 r14 displays (128 is NOT the temperature but the software and revision of the board)
Normal startup of heater begins (blower, etc.)
Hopefully you're not basing your troubleshooting on that number. The LEDs on the back of the board will direct you to the best place to start. Did you try running the heater with the thermal regulator out? Did you look into the manifold and see if the internal bypass is broken?
Short cycling is almost always the result of, first poor water flow through the filter system, just enough to close the pressure switch but too little getting too hot tripping the high-limit or ags switch. Or, second poor water flow through the internal passages of the heater, most notably the internal bypass. Too much water bypasses the heat exchanger, the rest gets too hot and trips the High-Limit or Automatic Gas Shut-off switch (not sensors).
Perhaps I misunderstood, but this is from your earlier post: "here's heater startup video... kinda tough to shoot alone but if you missed it, the heater comes on, the red lights both flash, it displays 128 as a temp, then R14, then the water temp... and the heater light beging to flash amber indicating the demand for heat is there."Hi, have not checked lights in back of board yet, nor running with regulator out. I plan to do that today and tomorrow. Got a lot of stuff on the go. And no I did not base my troubleshooting of the thermistor on the startup numbers, it was based on the temp showing 126 (not 128) and not coming on at all. New thermistor allows it to come on but short cycle like last year. When I pull the regulator i will take a photo of the internal
Bypass if that can be seen via the chamber. Agree blower sounds a little rickety. Can’t recall if it always sounded like that or if that’s “new”. Believe it always had that sound. More work to do here!!
yes you are right, that is what I wrote, but I was the one mistaken... I should have just said it says 128 , then r14... I was thinking it showed 128 where the temp is normally shown... but it came out wrong. apologies. I can swear on my pinky that when it wasnt lighting at all, the water temp (not the startup code) was reading 126... as written the new thermistor fixed that. still baffled about the old thermistor. it looks very good and gives correct readings on my meter. I also dunked it and it was still ok underwater and giving me the correct resistance to the water. my best guess is that the leads on it were brutally corroded. so I will hold onto it with my basket of pool parts and maybe use it someday if the aftermarket one fails. give it one last chance to prove itself.Perhaps I misunderstood, but this is from your earlier post: "here's heater startup video... kinda tough to shoot alone but if you missed it, the heater comes on, the red lights both flash, it displays 128 as a temp, then R14, then the water temp... and the heater light beging to flash amber indicating the demand for heat is there."
It is possible that there were/are two issues with the heater, a bad the thermistor that can test good out of the heater (replaced?) and a bad internal bypass, which can cause short cycling.
No reason to put it on the shelf. Ten-minute job.yes you are right, that is what I wrote, but I was the one mistaken... I should have just said it says 128 , then r14... I was thinking it showed 128 where the temp is normally shown... but it came out wrong. apologies. I can swear on my pinky that when it wasnt lighting at all, the water temp (not the startup code) was reading 126... as written the new thermistor fixed that. still baffled about the old thermistor. it looks very good and gives correct readings on my meter. I also dunked it and it was still ok underwater and giving me the correct resistance to the water. my best guess is that the leads on it were brutally corroded. so I will hold onto it with my basket of pool parts and maybe use it someday if the aftermarket one fails. give it one last chance to prove itself.
I agree with you there are 2 issues with the heater. the thermistor definitely was sending a bad temp code... how and why is a mystery but the new thermistor is not doing that. The other issue remains unsolved... and so far today non-reproducible. that is the short cycling. as I said leaving it on for a solid hour to see if anything happens. is it safe to say if my regulator wouldnt open under tap water, that I may was well swap it when the new one arrives this week?
Only reason is the other old one is now working somehow? No short cycle heater been on for over an hour and pool temp up 3 degrees already. Could save the new part for when there is failure?No reason to put it on the shelf. Ten-minute job.
296… looks right in the good spot.Exhaust Gas Temperature.
While running, press and hold the On button to display the exhaust temperature (Older Models).
The new models use the Menu to get the SFS.
Here is what the normal exhaust temperature should be:
Note: HD models can be up to 75 degrees higher. HD models use a cupro nickel exchanger and the efficiency is slightly lower resulting in less heat transfer and more waste heat.
- Below 250 degrees...very low
- 250 to 290 ..................low
- 290 to 350.................acceptable
- 350 to 480 ..................high
- Above 480...................error/shutdown.
If the exhaust gas temperature is higher then normal then water may be bypassing the heat exchanger through a broken bypass valve.
If you hold down the "pool on" button, it stays on 80, then flashes to 40, then back to 80, then the 80/40 reading and E05 indicate that the board is not getting a reading from the sensor. It's usually a bad sensor or damaged wires.
To be clear: my expectation is that the heater will stay on until the set temp is reached, even if it takes hours and it will not cut in and out if all the sensors and valves are working properly. Is this correct, or would it be normal duty cycle for it to periodically cool off by stopping combustion?296… looks right in the good spot.
