Thermal limiter was missing.
chrger1970
Active member
Jun 21, 2014
31
Holmdel, N.J
I was troubleshooting my Mastertemp 300 and changing all the usual sensors and the control board. I checked the thermal limiter and found the thermostat and the spring were gone. I’m thinking the spring must have rusted and the thermostat must be in the manifold. My question is, how far can that Dang thing go? It must be causing a problem because now I’m getting a PS LED light telling me it’s the pools pressure, which make sense as the thermostat could be causing a blockage. Thanks guys for any help.
You need to remove the manifold, open it up, and see what parts you can find. It is 8 bolts to remove. Get the O ring kit to replace all the O rings while you have it open.
Reactions: chrger1970
PS LED is telling that there is not enough flow to close the pressure switch, usually a dirty filter or clogged pump. Sometimes the thermal regulator is removed for testing, the heater works, and it is not replaced. Parts are too large to get into the heat exchanger and would be very visible just looking into the port.
