- Jul 21, 2013
- 54,179
- Plaster
- Pentair Intellichlor IC-60
I used to live just south of you in Hanford. I feel your pain and don't miss living the in central valley at all.one of the worst air quality basins in the country for two months of every year
Yeah I work in Hanford.I used to live just south of you in Hanford. I feel your pain and don't miss living the in central valley at all.
So many great posts
Directed my neighbor to local independent pool store before I tested his water as he is shopping for pool service. I used to buy 12.5% from them as well as filter parts they keep in stock. I often chatted water chemistry with them and was encouraged, not TFP level but better than Lesters....
Anyway I suggest he take a water sample that I pulled from his pool into them, he did and they have this digital test device they use. It has a round cartridge and reads the analysis in mere seconds. I tested CH at 500+ they test 600, I test CYA at 200+ they test at 70 , I test again today and still 200+ being precise with the dilution and test procedure. Clear to me he must drain, they advise against that citing temps, plaster risks ( I agree but can be mitigatrd) and that 70 CYA is high but managable (my 200+ is not) and CH at 600 is not an immediate issue (ok maybe but 2 birds one stone).
I'm walking a fine line now. I will make my case and stand behind my test results to the pool store, the new pool service and my overwhelmed neighbor, then I will stand down and let the smoke clear ... waiting for the train.
There are some interesting proposals out there that in theory sound great.Well, yes and no.
Desalination requires energy. You either use distillation (heat and pressure) to remove the minerals in water or you use reverse osmosis (mechanical energy). Both of those are energy intensive processes and, it’s California, so they already don’t have enough energy to go around. Also, desalination plants are built in coastal areas. Once the fresh water is created it has to be transported. Anytime you have to physically move water more than a hundred miles or higher than a few thousand feet, the costs skyrocket. So, at the end of the day, desalination water is probably the most expensive form of water you can utilize.
The Aussies have some very cool desalination tech based on the use of wave energy to power the desalination process BUT you still have to transport the water which adds up fast.
About the only place on the planet that makes sense to desalinate is in the Middle East where oil is cheap and plentiful and there’s no other sources of water to begin with.
The dilution instructions clearly say that the variance for error increases with each dilution so it's just an 'about'. At 9-1 you might be better just tasting it.I will have to dilute 9:1 to find the range of the Taylor reagent test
Is that a thing? With enough effort, could I develop the skills to just taste the water and know what to add? Like a human TF-100!The dilution instructions clearly say that the variance for error increases with each dilution so it's just an 'about'. At 9-1 you might be better just tasting it.
There was a post awhile back (last year maybe?) where someone reported their “pool guy” just tasted or smelled their water and said “yep, all balanced” as some sort of demonstration of their amazing skill and the fact that a homeowner couldn’t do what they do.Is that a thing? With enough effort, could I develop the skills to just taste the water and know what to add? Like a human TF-100!
With the vast majority of the CA population living near the coast transport costs shouldn't be a showstopper. The water provided by a desalination plant in Huntington could supply the local market, and they could stop importing water or import less ( i.e. LA aquaduct). I know the Owens Valley locals for one would appreciate it immensely.Desalination requires energy. You either use distillation (heat and pressure) to remove the minerals in water or you use reverse osmosis (mechanical energy). Both of those are energy intensive processes and, it’s California, so they already don’t have enough energy to go around. Also, desalination plants are built in coastal areas. Once the fresh water is created it has to be transported. Anytime you have to physically move water more than a hundred miles or higher than a few thousand feet, the costs skyrocket. So, at the end of the day, desalination water is probably the most expensive form of water you can utilize.
