The MX8 weighs very little, which is probably why it can climb walls so easily. My 8 year old boy can easily pull it out of the pool, though that hasn't been a problem.
Since it does surface so easily, it can indeed pull air into the line. I have noticed that a couple of times, this has caused my WhisperFlo pump to lose prime. I will probably have to turn down the suction a bit on it so that enough water comes through that it doesn't suck enough air into the pump to cause it to lose prime. Alternatively, I may just add a little weight to the unit so it doesn't do this. That's the only niggling feature about this unit, otherwise I think it really does a great job.
