The Taylor color change has a one drop uncertainty in my practical use (I now know what "level" of color change is correct, so I can use the tests interchangeably). The "other kit" goes from purple to clear instantly. I just like the other kit's TA better. They give EXACTLY the same results.
I have a neighbor who is color blind and he had a **** of a time with the Taylor TA kit and he has no problem with the other kit. Since they give the same correct consistent result: both are good.
I am an electrical engineer and not a chemist (I almost majored in Chemical Engineering but decided not to when I found out 90% of the jobs were in the petroleum industry). So I would have to say this is one of the RARE cases for me that I don't care about what is happening under the hood, just the results. When I have more time, if I can ever retire, I might pick up my 17-yr old self's interest in chemistry again!
I regret never taking a formal Organic Chemistry college class.
One of the valid criticisms (in my never humble opinion) of this web site is that the test kits are seen as something "sold" here. I know that's not true and even when they are they sold are not a high profit item. But to say that only Taylor makes good water testing kits is a fallacy and it helps to defeat the actual purpose of what we are trying to accomplish here. What is important is accurate and repeatable results.
A lot of people seem to hate LaMotte here. In the beer brewing water testing groups they are seen as the best. I suppose it depends, doesn't it? It's obvious from looking at their product line pool testing isn't a high priority for them.
But strips still suck. They are too uncertain. Just by design. I think they could be potentially made good if they had finer range.. but in most cases you can't accurately act based on strip information. They are too vague.
What I want to do now is try to neutralize a water sample down to almost zero with the chlorine neutralizer drops out of the other kit, and then see if the pH reading is different in a controlled environment among all of the tests at a couple of different starting Cl levels . I'll have to wait until the weekend though. OR whenever.
