My 2-wheel pool cleaner stops every minute or so and then starts up again. In the last few months I have replaced the rear skirts and the turbine/vanes. It was doing a great job after the skirts were replaced until the vanes got jammed up and no longer stayed on the turbine. It’s working okay but not as good as it used to and just stops once in awhile. It seems to be part of the “timed routine”. I am looking at replacing the shafts but am not sure if that’s the problem or if I did something wrong putting it back together after installing the turbine. It looks right but anything’s possible. Has anyone else had this issue? Thank you!
Chris
22K gal, IG Plaster w/waterfall, Pentair Intelliflo VS 3hp
Hayward Poolvergnuegen Cleaner & Filter Cartridge
Chris
