The infamous Jandy e-pump squeal
Aug 24, 2016
27
Las Vegas, NV
Another winter means tolerating this hideous noise from my Jandy e-pump again. I’ve had this thing at least 5 years now. It seems to be a common problem and yet I can’t find anyone who has definitively solved it. Whenever it gets to be below about 40 degrees, this monster starts the same shrill cry. It comes from the back of motor like it’s got something to do with the rear bearing. It never becomes anything more than a major nuisance as the pump works flawlessly at all times.
Somebody make it stop!!!!! 🙉🙉🙉🙉
The black rubber is the motor shaft seal.
Thanks James. If it helps, 1poolman1 let me know the following when I posted on the same issue a while back:
Your pump is one the ones that had a Century (owned by Regal Beloit) V-Green 2.7 motor (or at least model of the V-Green made for Jandy, they would never say).
Yes, I remember discussing this exactly 2 years ago on January 21 2023.
Jan 21, 2023
Try replacing the seal with a good seal.
If it's not the seal, it is probably the bearings.
Jan 21, 2023
Wouldn’t a bad seal result in leaking water, especially after several years?
I’ve seen another thread where Jandy replaced the whole pump and motor and the problem still resurfaced with the replacement.
It’s hard to believe that nobody has identified what the issue is for sure. I hate to replace bearing or seal and end up trading the noise for something worse so I continue to endure. Haha
The motor-shaft seal is not the one that prevents water leaks, that is the pump-shaft seal. Motor shaft-seal is there to protect the motor if the pump-shaft seal leaks, though it seldom really does unless the water leak is caught and repaired quickly.
The motor shaft actually rubs against its seal and that can cause a squeal. It takes dismantling the pump to do what is described in the troubleshooting guide as a fix, so guess how many people actually do that or want to pay to have it done.
I’ll play—ZERO. 😅
  • Wow
Reactions: JamesW
