Looks like a gas fired heater not a heat pump. Either way, not many of us want to see a $900 utility bill.
Can you explain to me what a heat pump is VS the heater? Just for my info.
A heat pump is like a reverse air conditioner. It would run on 240 volts & not have a gas line. I'll find a link that'll explain it better than I can.
Here's a Wikipedia article. https://en.wikipedia.org/wiki/Heat_pump
Hayward will email you a nice comparison of the estimated costs for heat pumps vs heaters.
https://www.hayward-pool.com/shop/en/pools/HeatPumpAnalysis
So is a gas fired heater like a water heater but with no tank? And does it make it less efficient than a heat pump? I read the wikipedia link and looked at the video that fklash linked and understand a little of the process. I sent in the comparrison, thank you!
Love to learn! (Althought it gets more difficult these days)
POOL DATA | FUEL PRICES | POOL HEATER | |
Size: 544 sq. ft. | Electric: $ 0.167 $/KWH | HP21404T | |
Volume: 18311.04 gallons | LP Gas: 2.342 $/Gallon | ||
Desired Temperature (F): 85 | Oil: 2.590 $/Gallon | ||
Covered: No | Natural Gas: 1.490 $/Therm |
MONTH | HEAT REQ'D MILL BTU | LP GAS | OIL | NAT. GAS | ELECTRIC | UNITS REQ'D | HP21404T HEAT PUMP† | |
MAY | 61.80 | $2,427.18 | $2,286.59 | $1,416.64 | $3,023.90 | 2 | $610.92 | |
JUN | 45.78 | $1,798.07 | $1,693.93 | $1,049.46 | $2,240.13 | 1 | $403.09 | |
JUL | 40.18 | $1,577.96 | $1,486.56 | $920.99 | $1,965.90 | 1 | $333.98 | |
AUG | 42.64 | $1,674.64 | $1,577.64 | $977.42 | $2,086.35 | 1 | $357.54 | |
SEP | 53.75 | $2,111.05 | $1,988.77 | $1,232.13 | $2,630.05 | 2 | $488.36 |
POOL HEATED 5 MONTHS/YEAR |
HEAT REQ'D MILL. BTU | EFF'CY (%) | LP GAS | OIL | NAT. GAS | ELECTRIC | HP21404T HEAT PUMP† | ||
Covered | 115.19 | 230.12% | $4,523.97 | $4,261.93 | $2,640.45 | $5,636.18 | $1,040.45 | |
Uncovered | 244.15 | 230.12% | $9,588.91 | $9,033.50 | $5,596.64 | $11,946.33 | $2,193.88 |
†This is an estimate. Actual costs will vary based on specific usage needs. |
This analysis is based upon normal (average) weather conditions gathered by NOAA. Your actual costs may vary based on the current year weather conditions. |
Please ask your pool professional about these other Hayward products that are sized appropriately for your pool: Summit model SUM8TA |
Here's the comparison Hayward sent to me:
Custom pool heating analysis
POOL DATA FUEL PRICES POOL HEATER Size: 544 sq. ft. Electric: $ 0.167 $/KWH HP21404T Volume: 18311.04 gallons LP Gas: 2.342 $/Gallon Desired Temperature (F): 85 Oil: 2.590 $/Gallon Covered: No Natural Gas: 1.490 $/Therm
MONTH HEAT REQ'D
MILL BTULP GAS OIL NAT. GAS ELECTRIC UNITS
REQ'DHP21404T
HEAT PUMP†MAY 61.80 $2,427.18 $2,286.59 $1,416.64 $3,023.90 2 $610.92 JUN 45.78 $1,798.07 $1,693.93 $1,049.46 $2,240.13 1 $403.09 JUL 40.18 $1,577.96 $1,486.56 $920.99 $1,965.90 1 $333.98 AUG 42.64 $1,674.64 $1,577.64 $977.42 $2,086.35 1 $357.54 SEP 53.75 $2,111.05 $1,988.77 $1,232.13 $2,630.05 2 $488.36
HEAT REQ'D
MILL. BTUEFF'CY (%) LP GAS OIL NAT. GAS ELECTRIC HP21404T
HEAT PUMP†Covered 115.19 230.12% $4,523.97 $4,261.93 $2,640.45 $5,636.18 $1,040.45 Uncovered 244.15 230.12% $9,588.91 $9,033.50 $5,596.64 $11,946.33 $2,193.88
†This is an estimate. Actual costs will vary based on specific usage needs. This analysis is based upon normal (average) weather conditions gathered by NOAA. Your actual costs may vary based on the current year weather conditions. Please ask your pool professional about these other Hayward products that are sized appropriately for your pool:
Summit model SUM8TA
Yeah, that Hayward estimator is total bunk. They got everything wrong. My NG costs are way lower than that and where I am, gas heating is A LOT CHEAPER than electric heating even in the dead of winter. I think they're just trying to sell heat pumps.
Do I dare post a pic of the grandson and me actually in the pool?
Hey! I might be gettin the whole thing about once I get rid of the "greenies" I won't have to do it again. For the last 6 days I've noticed that the FC loss has not been more that 1ppm and the CC has gone from .5 to <.5 to now 0. I've tested at 6:30 am and if the FC loss was 1 added 32 oz of Clorox (per pool math), but I've only had to do that twice this week. I am still using the FAS/DPD since I'm keeping the FC at 6-7. The pH has drifted up to 7.5 on its own (did not add Borax after my muriatic acid overdose).
After my wild ride gettin here I can't believe how calm and serene my pool has been. I love it!
I'm thinking since the FC has stayed rather constant and the CC is <.5 - 0, I will let the FC come down to 5 - 6 range?
Would anyone recommend I bring the pH down to 7.2 since my CH is still high and I'm concerned about scaling? Other #s:
CH 625 TA 70 CSI 0.06
Thanks!
that is really great, I am so happy for you
ok, your TA is 70 so lets see if your ph stays about 7.5/.6 on its own, watch it.. if it goes up to 7.8 take it back down to 7.2 and see if it will stay down.. you are trying to find a "sweet" spot for your TA and PH where it stays under 7.5 or so
