- Jun 17, 2012
- 54
- Vinyl
- CircuPool RJ-60 Plus
We recently moved into a house with a green pool. I immediately installed a SWG and started the SLAM process. In less than 2 weeks the water passed the OCLT and I dialed in the SWG % and got the pool into “cruise control“. I was headed out of town for work for a few days so my wife asked what she needed to do pool-wise, so I said just make sure the pump comes in and throw the Triton in Monday morning. Sunday night there was a large storm (lots of stuff from the yard washed into the pool) and she woke up to a “brown” pool. I got home last night and took a full set of readings this morning.
FC/CC 16/0
pH 7.4
TA 80
CH 120
CYA 65
I had her test on Monday and the pH was around 8 and I had her add 3 lbs of CalHypo 75% to increase the amount of FC till I could get home.
The water was balanced as per the Pool Math ranges, although I was working on lowering TA from the high side of the range due to quickly rising pH levels.
Unless there are better ideas, I’m starting the SLAM process again.
FC/CC 16/0
pH 7.4
TA 80
CH 120
CYA 65
