Howdy folks,
Pool newbie here. First I'd like to say thanks to all of you. Because of this forum, I've learned how to maintain crystal clear water and all of my physical pool equipment. You've also given me the courage to download SLConfig and re-program my EasyTouch, which is now working just as I'd like it to. So, thanks! Special shout out to @Jimrahbe and @JamesW for their guidance and insight related to programming the EasyTouch! Your posts have been super helpful.
I have two final questions related to my pool's Automation System.
First - I have a Pentair Ultratemp 140 H/C. The heat pump is setup on the Solar circuit of my EasyTouch, so I can set the temperature range that I wish to keep the water within. I'm in Austin, TX, so mostly dealing with chilling now that the summer has finally arrived. I've noticed (and have read here that this is an issue) that occasionally my pool temp as read by the automation system can oscillate at the high end of the set temperature range such that the heat pump turns itself on / off every few minutes. I don't want to burn out my equipment, so I've been manually monitoring when my heat pump turns on to chill the pool during the day, and sometimes adjusting the upper boundary so that the system just remains on vs. the on/off cycle. Eg. Upper bound set at 88 degrees, automation system reads temp at 89, then back to 88, then back to 89. So I reset the upper bound down to 86 until later in the afternoon when I manually put it back up again. I'd like to figure out if there is a solution to this. I believe I've seen some threads about a possible hardware / software solution, but I can't seem to track it down. Any help appreciated!
Second - The gallons per minute reading visible on my ScreenLogic app is different from the flow meter physically attached to my pool plumbing. I have an inline FlowVis flow meter located just after heat pump exit and just before the main and paramount in floor return valves. The reading on the FlowViz is typically about 10GPM higher than what is displayed in ScreenLogic. Eg. When I look at the Flow (GPM) reading in ScreenLogic, it shows me say 46GPM @2500 RPM on the Intelliflo. When I look at the FlowViz I see between 55-60GPM. I've asked my PB about the calibration of the EasyTouch/Inteliflo flow sensor, but he's not been able to provide an answer to me. My questions are, where does the flow value displayed by ScreenLogic come from (the Intelliflo, a sensor?) and is it possible to calibrate the sensor? I'm assuming for now that my FlowVis is what is accurate, due to the fact that the Ultratemp has never refused to turn on due to lack of flow (I always keep the flowvis at or above the 30GPM min for the Ultratemp, even though the ScreenLogic will show approx 10GMP less) and it's a physical gauge. But, I really don't know for certain which reading is the most accurate.
Any help appreciated, and thanks again!
John
John
