Just went to the pool store as I was going to buy stabilizer based on my result. Since I was there I brought a water sample. All the readings were close except CH was lower however I understand the TF100 adds a chlorine neutralizer so I get that - He test 155 / mine was 175 , I could live with this. However the CYA on his test was 28 where I am showing Zero this morning - I can see the dot with the tube filled to the top. Now yesterday my reading was between 20 & 30 so I am surprised it dropped all the way to zero over night - Anyway , I did not buy stabilizer and right now not sure what I should do -
I could float 1-2 tabs this week as the effects of adding on the pool math app shows CYA increase of 4.7 , which even if the pool store is right that is still only like 32-25 total CYA when they burn off. It will keep the FC around 7 pts higher which is well under shock value of 16 . Seems like a safe bet ? Pool guy did not try to sell anything, if fact said everything was good and the CYA is close to the 30-50 range that I should not add.
