Tf-100 test results
FLdrv
4
Valrico, FL
Greetings, first time posting and just tested the salt water with my test kit. Instructions were straightforward. That surprised me. 5 stars there. A little unclear in my chicken or the egg dept.
Cc 3.5 ppm
FCC 3.5 ppm
Tc 7.0 ppm
Ch 250 ppm
TA 40
PH 7.6
CYA could still see dot
*started stabilizer in sock in skimmer basket and dialed down swg to 10 percent.
Thanks
Pool 13,830 gal fiberglass
Hi, how does your water look? Is it cloudy or is there algae? Your combined chlorine is high enough to indicate a need for the SLAM Process
What all have you put in the pool besides chlorine and CYA? Any nonchlorine shocks or pool store products??
You tested a CC of 3.5ppm. That would make your pool water stink of chlorine. Otherwise, I would redo the FC / CC test.
