I have a lot of trouble getting an accurate read on PH- the best I can tell it hovers right around 7.8. However when I add 5 drops to the container it doesn't match anything on the test block. When I asked about it previously here someone recommended I add 4 drops and see if that helped get a result, and it did. When I add only 4 drops of liquid it almost perfectly matches the 7.8 test block color. (Yes, I'm using a white background in full light).
My question is- is it okay to use 4 drops regularly or is my PH really above 8 and I just don't know it because I'm using 1 less drop than recommended? When I add the 5th drop it turns a dark red, but not the bright pink of the 8PH on the test block.
