I ran across the instructions for doing this test:
www.troublefreepool.com
I used distilled water, measured out 1000ml using a graduated cylinder, then added .1ml of my chlorine
using an old insulin syringe. When I added the dpd powder, it turned yellow instead of pink. Tried adding the R-0871 anyway, but nothing changed.
Any ideas what happened??
Thanks.
Chlorine Date Code Decoder/Easy Way to Measure Strength.
Just divide the day by 30 and that gives you the month. Really no need to be more accurate than that.
Thanks.
