Good afternoon! I am wondering if I could get some advice.
I am a little frustrated with how inconsistent my tests have been recently.
First pH, I was using a pH meter I got from Amazon. I had one before, but not sure where I got it from. However, the readings were not consistent with the Phenol Red tests. After reading the forums, I started relying on the Phenol Red tests and trying to calibrate the meter.
Now I am rethinking the vial tests, as I have usually used the chlorine drop test for my FC. However, I have noticed that the readings are not consistent with the vial R-0600 tests. Which is more accurate? How can I determine what is more accurate and when my products go bad?
I purchase the TF-Pro test every year to make sure the products are not expired. My test results are placed on PoolMath.
I'm trying to get my TA under control, as well as my CH (drained about 50% of the pool about 2 weeks ago).
