- Jan 3, 2023
- 344
- Plaster
- Pentair Intellichlor IC-40
I tested my fill water a few minutes ago, and for the first time, the tap water. My fill water does not run through my softener or filter. That said, when I tested the fill water, I got a CH of 50, which is about what I suspected, as we have fairly soft water. However, when I test my tap water which goes through my filter and softener, after I put R-0011 solution in the vile, it immediately turned blue.
Question: I have to guess that since Red indicates the presence of calcium, if it turns blue when the R-0011 solution is added, there is a minimum threshold for that solution to detect calcium. If so, what is that threshold? Doesn't impact anything other than a better understanding of the tests I am using.
Here are my Tap results:
Chlorine: 1
PH: 8.04
TA: 160
Calcium: N/A(?)
Fill Water:
PH: 8.03
TA: 160
Calcium: 50
Chlorine: 1
PH: 8.04
TA: 160
Calcium: N/A(?)
Fill Water:
PH: 8.03
TA: 160
Calcium: 50
