Hi,
I am experiencing some slight algae and have initiated the SLAM process. My CYA is 60 so SLAM is done with FC of 24as per the chart; however the taylor k2006 kit says FC testing with fas-dpd is accurate up to 20ppm. How should I proceed in this case in particular when doing an overnight loss test? If this is not accurate i will not be able to confirm if i pass the <1ppm loss, right?
I would appreciate any advise.
Thanks!
Thanks!
