Test strip help needed until TF-100 arrives
Jun 23, 2023
19
Las Vegas Nevada
FS-100 kit +ph meter is on its way.
Need some early advice using test strips.
6 days ago noticed some green algae on walls (hadnt seen the service guy in over a week, fired him)
Added 4 3" tabs to the 2 floaties, brushed walls
Used tested 2 days ago for these results, any suggestions till the kit comes in?
Ph FC TA Cya
Normal tap water 6.8 0 180 0
Pool day 1 test 7.8 2 180 30-50
Pool day 2 test 6.6 4 180 30-50
Pool pump/bottom vac with wall fountains runs 8 hrs a day.
What say the experts?
While waiting on the test kit, add 5 ppm FC worth of liquid chlorine to the pool each evening with the pump running.
If you wish to test pH, get a cheap two way kit at Walmart. That should give you a pH reading as long as FC is not high (which will be unlikely.).
