For the CYA test, there's a few tricks that help.
Pool water to lower line, with bottom of meniscus at the line. Top off with CYA detection reagent until bottom of meniscus is at upper line
Swirl or invert repeatedly for 30 seconds; waiting longer seems to help me get a good reading, so I mix it before the other tests and then read CYA last.
Hold the viewing tube by the top edge with thumb and forefinger
Hold viewing tube at waist level with your back to the sun
Pour from mixing tube until you can't make out the CCL logo at the bottom any more. You may see a bit of darkening, but definitely not make out that it's a flask
Don't stare; look away and then glance - do you see the flask shape right away? If so add a bit more.
When you're done, pour it back into the mixing tube
Repeat the reading by pouring the same solution again. Do this as many times as you like, until you're getting a reasonably consistent reading.
The CCL kit has a 50 ppm standard with it, so after you get the technique sorted, try testing that standard the exact same way, and see how it looks. If need be, after using the mixing tube to add the CYA detection reagent to a sample of the CYA standard, walk around your yard testing until you find the right lighting and get 50 ppm.
It helps to understand how the test works. The CYA detection reagent has melamine that combines with the CYA forming small white particles. The particles need lots of light to create the turbidity, but if the black logo at the bottom is also well lit from above, it makes it easier to see.
oh yeh, do you know the weight of CYA added? It will almost all still be in the pool water, and we can calculate the ppm CYA.
Most everyone has trouble with the CYA test, so don't feel alone, mate!
