- Jul 21, 2013
- 65,741
- Plaster
- Pentair Intellichlor IC-60
I'm @ 7.4 pH, with the CYA also lowering it a bit, is that sufficient?
That is good for the SLAM.
This test is done with a 10ml sample, not 25. The directions can be confusing. Is this what you used?Salt: This test didn't work for me, liquid was getting cloudy, but no color change to 'salmon-y, brick red
Yeah, that's exactly what I did...filled to 25ml. My fault it says "using the 25ml" and I just filled to 25ml! I did retest with 10ml, and salt was at 3100. Thanks!This test is done with a 10ml sample, not 25. The directions can be confusing. Is this what you used?
Okay, meant to post earlier...water looks super clear, and my CCs were under .5 this morning. I'll do an OCLT tonight for the final hurdle. Thanks!
Okay, so results this morning were: .5 or less CCs, 1ppm FC loss overnight, water is clear. I think I'm good to go?
Was at 11ppm FC when I tested it at 9pm. I wasn't going to have time to add chlorine and retest, so I left it at that. A 7am water sample tested at 10ppm FC.What FC level did you start with last night?
CYA is currently near 30.
