- Mar 25, 2021
- 114
- Plaster
- Pentair Intellichlor IC-40
So it’s going to be a chilly night tonight (low 30’s F which is cold here in the desert southwest) and I have this great idea to heat up the hot tub, turn off the lights, and watch the Geminids meteor shower from the cozy warmth of the hot tub.
But its likely that the EasyTouch’s freeze mode will be activated, will turn on the infloor cleaner booster pump, which will periodically pump 48 degree pool water into the spa through the cleaner jets.
As well, as I see freeze mode alternating between pool and spa while in pool mode, I expect it would be doing the same while in spa mode, this returning cold pool water to the spa for the spillover. Thus rapidly cooling the spa.
Aside from going into the circuit programming and turning off freeze mode temporarily on pool and cleaner circuits, is there a better way of accomplishing this?
