Hi Jim,
Thanks for your reply. I was playing with it a bit today. First, I don't have the screenlogic set up yet. We're still in the build process. He'll be installing it later on.
I found that the easytouch isn't controlling the heat pump. I adjusted the easytouch to set the pool temp down to 76 (current pool reading was 80 degrees on water temperature probe). It didn't cause the heat pump to turn off. However, adjusting the temperature control on the heat pump turned it off.
I'm not sure about the difference between relay connection vs serial cable. He says he installed it into the com port on the easytouch.
The poolbuilder is focused more on getting the pool ready for concrete pouring while the weather is still okay. I'll let him play with the electronics once that gets done.
I'll post how things go.
