Temp sensor replacement
Jared07
24
Belle Chasse, LA
Jandy Aquapure 1400
Fellow Pool gurus,
Our water temp sensor is reading 130-135 but heater and temp gun have the water at 70ish degrees (70 for heater sensor and 68 via temp gun on surface water). From research here it appears the sensor is bad. All the equipment is Jandy and ran via iAquaLink 2.0. I want to make sure I order the appropriate sensor. Can anyone identify the current sensor and a suitable replacement? We moved into the house and the pool is ~7 years old with very little documentation outside of the owners manuals. Just want to make sure I put something in that’s compatible and don’t waste the $$ on a pool service call. Thanks!
save yourself $80 and buy generic -
AR-PRO 520272 Air/Water/Solar Temperature Sensor with 20-Feet Cable Replacement Pool/Spa - 2 Pack https://a.co/4APDMiJ
The big manufacturers versions are no different than the generic. It’s a 10kOhm thermistor and paying $100 for one is RIDICULOUS.
