Teal pool color, 18 x 35x 8ft depth pool
Tnethpdx
19
Portland, Oregon
Now on Day 5.
The color changing is heading in the right direction.
It’s now a teal cloudy color. Not yet blue.
I shocked it again tonight.
My thought is because it’s been 5 days of this process it’s time to clean the filter bc my PSI went from 10 to 18.
Filter is running.
I am currently waiting for my Taylor 100 pool test kit.
I am having hard time seeing how to stop water from flowing into my Pentair Filter. I was draining from bottom and feels like it’s a lot. Previous owner have electric plugs placed nearby the furnace and if I drain from drain valve, all the water would Cover that outlet so I have been using a wet vac to vac how much ever I can.
How do I get the water to empty in return line as much as possible? I have the skimmer line closed and all Power shut off before I tried to do this. The main circuit breaker and the breaker on/off switch next to the pool pump.
Welcome to TFP! :wave: The SLAM Process works when done properly. That will resolve most of your issues, You do need the proper kit though. Which one did you order? Your signature is blank so we have no idea about your equipment. Yes, we clean/backwash the filter when the pressure increases by about 25% from its clean pressure.
Reactions: Tnethpdx
Thank you. I just updated my acct with my signature :)
Reactions: Texas Splash
Great! :goodjob: When you get a chance, please post a full set of your own water test results and we'll check to ensure you're on track with the SLAM Process.
Reactions: Tnethpdx
Currently I only have a 2 way test kit. This is the results:
CL 3.0
BR 6.5
pH 7.2
I ordered my TF-100 kit and should be arrive within next 5-7 days.
I just added the pool update this morning.
Are those yellowish that float to top yellow algae?
