Taylor K-1106 confusion
May 14, 2018
49
Doylestown Pa
I bought this test kit but and confused on how to check the results. It comes with 2 cards that have the same colors. I’m not sure how I should be holding the time to get the readings. Anyone have any insight? Do I look through the cloudy side of the tube? I can’t find clear instructions anywhere.
You have two different tests in one kit. You have two sets of directions and color comparators. Compare the directions and you will see the chemical mix is different. Follow the directions and mix for the color card you use b
