Target Help Pool MAth
Because you will lose some to sunlight and swimmers every day. You don't want FC to drop below the minimum before you next add. If you target 5 and in 24 hours you're at 2, then you need to target 6 instead. You'll just have to test and monitor things for a couple weeks to learn your pool's unique personality. The y key is to always stay above minimum.
