Hi all, currently we have a 1hp hayward pump and 1-1/2" PVC coming out of the filter and into the ground (eventually into the pool, lol) as pictured on the left:
On the right, as you can see I want to hook up a 1/2" PVC pipe supplying hot water that uses a separate 1/25hp (8 GPM) pump. I know the bare minimum on head loss/gain and all that. I read the "Hydraulics 101" post here which was helpful! But does this setup seem feasible? My hope is that since the water is already flowing down toward the ground, in addition to the check valve, this should work.
Thanks!
Thanks!
